Farymann D 20 Technical specifications
Verfasst: Sa 31. Mär 2018, 14:28
von Doru
Hello!
I have a D 20 f Farymann engine.I know about this engine:The Farymann Diesel engine type 28 D20 0048 n=1800 RPM is a horizontal air cooled 1-cylinder direct injected 4-stroke Diesel engine,
year of build 1974.
Output approx. 8 HP at 1500 RPM
The production of D20 engine type was ended in 1979.
I would like if you can help me with some technical specifications.
I want to know if the piston matches and the segments go by tractor? And cuzines(roller bearing), biela (the connecting rod), arbor (Crankshaft).Thank you.
Re: Farymann D 20 Technical specifications
Verfasst: Mo 2. Apr 2018, 13:32
von arturwernz
Hello,
what Piston do you mean and which segments? I have the complete technical sepcifications here and also can provide all parts to this engine.
Verfasst: Mo 2. Apr 2018, 17:19
von Doru
arturwernz hat geschrieben:Hello,
Hi! Piston(kolben), segments(bremsbackn-enheit).I hope this is the technically correct translation.The first picture are segments ,the second picture is a piston.
The pictures are informative only is not what I am looking for.
Verfasst: Mi 4. Apr 2018, 17:31
von arturwernz
Hello,
i don´t understand what do you want. The Piston needs to be 90mm diameter. Do you need a new Piston with piston rings (segments) or only the Piston rings?
Verfasst: Fr 6. Apr 2018, 17:33
von Doru
I'm looking for technical data about the piston, and cuzines(roller bearing), biela (the connecting rod), arbor (crankshaft)And I want to see if they matches from tractor 445.
Verfasst: Sa 7. Apr 2018, 10:55
von arturwernz
Good Morning,
could you send me your adress, I can send via letter post the documents.
So you can find out what you need.
BR
Artur Wernz
Verfasst: Do 12. Apr 2018, 13:22
von arturwernz
Hallo Doro,
hier die gewünschten Bilder.
Gruss
Artur
Verfasst: Mo 16. Apr 2018, 09:12
von Doru
Thank you very much Artur! Have a nice day!
Verfasst: So 22. Apr 2018, 13:44
von Doru
