Hello!
I have a D 20 f Farymann engine.I know about this engine:The Farymann Diesel engine type 28 D20 0048 n=1800 RPM is a horizontal air cooled 1-cylinder direct injected 4-stroke Diesel engine,
year of build 1974.
Output approx. 8 HP at 1500 RPM
The production of D20 engine type was ended in 1979.
I would like if you can help me with some technical specifications.
I want to know if the piston matches and the segments go by tractor? And cuzines(roller bearing), biela (the connecting rod), arbor (Crankshaft).Thank you.
Farymann D 20 Technical specifications
hatz e 108 10 ps n=1500
Re: Farymann D 20 Technical specifications
Hello,
what Piston do you mean and which segments? I have the complete technical sepcifications here and also can provide all parts to this engine.
arturwernz hat geschrieben:Hello,
Hi! Piston(kolben), segments(bremsbackn-enheit).I hope this is the technically correct translation.The first picture are segments ,the second picture is a piston.
The pictures are informative only is not what I am looking for.
- download.jpg (3.89 KiB) 466 mal betrachtet
- images (1).jpg (3.93 KiB) 466 mal betrachtet
Hello,
i don´t understand what do you want. The Piston needs to be 90mm diameter. Do you need a new Piston with piston rings (segments) or only the Piston rings?
I'm looking for technical data about the piston, and cuzines(roller bearing), biela (the connecting rod), arbor (crankshaft)And I want to see if they matches from tractor 445.
Good Morning,
could you send me your adress, I can send via letter post the documents.
So you can find out what you need.
BR
Artur Wernz
BR
Artur Wernz
Hallo Doro,
hier die gewünschten Bilder.
Gruss
Artur
Gruss
Artur
- 02_20180410_140141_resized.jpg (75.41 KiB) 193 mal betrachtet
- 04_20180410_140129_resized.jpg (77.15 KiB) 193 mal betrachtet
- 01_20180410_140149_resized.jpg (90.8 KiB) 193 mal betrachtet
- 05_20180410_140119_resized.jpg (83.85 KiB) 193 mal betrachtet
- 03_20180410_140135_resized.jpg (95.92 KiB) 193 mal betrachtet
Thank you very much Artur! Have a nice day!
Below is a link to the engine in operation:
https://www.youtube.com/watch?v=m2g0rc6XdO0
https://www.olx.ro/oferta/motor-faryman ... b6efcdc8ca
- Ähnliche Themen
- Antworten
- Zugriffe
- Letzter Beitrag
- 5 Antworten
- 742 Zugriffe
Letzter Beitrag von klausrinner
Neuester Beitrag
Mi 27. Dez 2017, 10:10
Vorstellungen
- 5 Antworten
- 1079 Zugriffe
Letzter Beitrag von arturwernz
Neuester Beitrag
Sa 2. Sep 2017, 11:01
Frage nach Motordaten
