Farymann D 20 Technical specifications
Doru
Meine Motoren: Farymann Diesel D 20
Beitragvon Doru » Sa 31. Mär 2018, 14:28
Hello!
I have a D 20 f Farymann engine.I know about this engine:The Farymann Diesel engine type 28 D20 0048 n=1800 RPM is a horizontal air cooled 1-cylinder direct injected 4-stroke Diesel engine,
year of build 1974.
Output approx. 8 HP at 1500 RPM
The production of D20 engine type was ended in 1979.
I would like if you can help me with some technical specifications.
I want to know if the piston matches and the segments go by tractor? And cuzines(roller bearing), biela (the connecting rod), arbor (Crankshaft).Thank you.
arturwernz
farymann-k5--4,5psn=3ooo farymann lcs 19ps n=19oo
hatz e 108 10 ps n=1500
Re: Farymann D 20 Technical specifications
Beitragvon arturwernz » Mo 2. Apr 2018, 13:32
Hello,
what Piston do you mean and which segments? I have the complete technical sepcifications here and also can provide all parts to this engine.
Doru
Beitragvon Doru » Mo 2. Apr 2018, 17:19
arturwernz hat geschrieben:Hello,
Hi! Piston(kolben), segments(bremsbackn-enheit).I hope this is the technically correct translation.The first picture are segments ,the second picture is a piston.
The pictures are informative only is not what I am looking for.
images (1).jpg (3.93 KiB) 1321 mal betrachtet
arturwernz
Beitragvon arturwernz » Mi 4. Apr 2018, 17:31
Hello,
i don´t understand what do you want. The Piston needs to be 90mm diameter. Do you need a new Piston with piston rings (segments) or only the Piston rings?
Doru
Beitragvon Doru » Fr 6. Apr 2018, 17:33
I'm looking for technical data about the piston, and cuzines(roller bearing), biela (the connecting rod), arbor (crankshaft)And I want to see if they matches from tractor 445.
arturwernz
Beitragvon arturwernz » Sa 7. Apr 2018, 10:55
Good Morning,
could you send me your adress, I can send via letter post the documents.
So you can find out what you need.
BR
Artur Wernz
arturwernz
Beitragvon arturwernz » Do 12. Apr 2018, 13:22
Hallo Doro,
hier die gewünschten Bilder.
Gruss
Artur
Doru
Beitragvon Doru » Mo 16. Apr 2018, 09:12
Thank you very much Artur! Have a nice day!
Doru
Beitragvon Doru » So 22. Apr 2018, 13:44
  • Ähnliche Themen
    Zugriffe
    Letzter Beitrag
