Krups ?
Kjell
Meine Motoren: Solo, Gray, Albin Meteor, Tune. Evinrude, Magne. Villiers and some unknown
Krups ?
Beitragvon Kjell » Di 17. Jan 2017, 19:23
Does anyone have pictures of a Krups onecylinder with overhead valves?
Motorenspezi
Re: Krups ?
Beitragvon Motorenspezi » Mi 18. Jan 2017, 20:48
Hello Kjell,
I do not know the engine, is it a German engine? Where was the deployment, stationary or marine?
Best regards Mathias
Kjell
Re: Krups ?
Beitragvon Kjell » Mi 18. Jan 2017, 21:00
Hello and thank You for Your answer!
I have been searching for any information about my marine motor for a couple of years and no response anywhere. But last week a norwegian told me it was an german Krups. Found nothing on Google
Motorenspezi
Re: Krups ?
Beitragvon Motorenspezi » Mi 18. Jan 2017, 22:47
Hello, your engine does not look like in Germany built, the water pump is not installed on German engines. Also the ignition magnet at the position is not usual. I will look at the weekend again, if I find something
Kjell
Re: Krups ?
Beitragvon Kjell » Do 19. Jan 2017, 06:48
Thank You!!
Re: Krups ?
Beitragvon motorenbau » Do 19. Jan 2017, 08:04
Hello
I don't know a German engine manufacturer named "Krups". Do you know the brand of the carburettor? Maybe this will help us. The position of the magneto might be rather typical for a French engine.
Kjell
Re: Krups ?
Beitragvon Kjell » Do 19. Jan 2017, 09:01
The carb is a copy of a Schebler no name on it
Kjell
Re: Krups ?
Beitragvon Kjell » Do 19. Jan 2017, 09:11
There are some odd things on the engine
Overhead valves
Strange place for the magneto
Funny inlet
Cylinder and upper part of block in one piece
